Swp instruction equivalant
I've been using SWPB for a long time.
As far as I can remember, it does the same thing as SWP did, except it has some more options for swapping bytes in DINTs.
I just did a little more digging and it looks like the SWP can swap an entire string.
In Studio 5000, SWPB can only be used INTs and DINTs one at a time..
You can copy (COP) the string to a DINT or INT, then use the SWPB, then COP back to the string. There may be a better way but I know this works.
As per manual i was tested with PLC on below program. But not any changes using swap instruction. plz help
2,029
Hello Sorry if this is not a really smart question but how do you use the SWP (swap )instruction in a Micrologix 1100 processor? I have got a...
3,837
Hi all. Never really noticed, but I started double checking operands in the CPT instruction. I found if I have the expression N7[37,1] - N7[35,1]...
155
I'm trying to dig to the source of a minor "recoverable" system fault throwing a fault light on a machine that has been confusing my operator...
128
143
