Symax Printout
booten
Jun 2004
Kansas
45
Does anyone know how to print out an old Symax DOS ladder program on the following system either to my printer or to pdf.
XP Pro
Canon printer through router & print server.
Will I have to connect a printer directly to the LPT1.
Or will have to locate an old system to get a printout.
Thanks,
Bill
I have done it on my system by printing to a file(.doc extension and taking that and printing it out in word.
If you need help, I can do it for you.
David
George,
Symate Plus V2.06
David,
Could you explain how to print to file? I have seen that as an option but had no success in trying it.
Thanks again,
Bill
Bill,
In Sy/mate Plus
F2 PLC Offline
LOAD RUNGS,LABELS,ETC
F7 Print Program
use the space bar to toggle your choices - what you want to show on the printout
F1 to get into Printer window
now use the space bar until Printer File shows up as a choice. Once you select a file name to print to, then hit F10 to save it to the file. You will probably want to "clean it up" some in a word processor.
George
George
Tried that and it is working, I had to create the directory for it.
It is printing now very slowly.
It notice that it is printing to a .prt extension. Can I open this in word?
Bill
Yes, it is really nothing more than a .txt file. And like george said you will have to clean it up for a non-dot matrix printer.
Bill,
Depending on your computer, the size of your program, and what you have asked it to do, it can take a few minutes. Especially if you ask it to do cross referencing, that adds time.
George
Hello, I was wondering if anyone has the ability to print SyMax PLC .P50 files to a .PRT, .PDF, or some other file I can open with a text...
1,318
I have a file that is supposed to be from a Square D Symax PLC. The file extension is .RNG. Would anyone with the Symax software be willing to...
2,723
Square-D Symax SFI-324 I have used the SFI-510 card for many projects, but I came across a SFI-324. Does anyone have ant tech info on it?
82
I have a few program files that I need to convert into a printable format. We don't have a dot matrix printer available to us. Would anyone be...
745
I have been tasked to upgrade some SquareD PLCs at our plant. I have done several of these upgrades without any issues. However, I have now met my...
2,447
