System Platform deployment anomaly
phuz
Jun 2008
Mohnton, PA
1,044
I'm testing something out on a Windows 10 tablet (1920x1080). I put together an InTouch View App, developed in 1920x1080 with 1920x1080 windows, but when I deploy it to the tablet, it appears zoomed in and doesn't show the full window. I can't think of any place that has a setting to do this.
It actually looks like its trying to display at 1280x720, hence the "zoomed" appearance.
InTouch.ini file?
What did application manager show when you first located the View file?
Have you deployed the same app onto a non-tablet PC?
You could like also consider Access Anywhere if you have a RDS license, but pout is your solution should work.
InTouch.ini file?
I had a smaller version of the app on another tablet (1280x800) which ran fine full screen. I then changed all the window sizes to 1920x1080 and deployed to the new tablet. That's when it happened. Although, I created a brand new instance at 1920x1080 and deployed that...same thing happened.
Application manager shows 1920x1080
If I go under the 'Node Properties' in the application manager and set the resolution for "Convert to screen video resolution," then it fills the screen. But I shouldn't have to do that. And it doesn't scale some of the text properly by doing that.
Hello, I am trying to implement some data coming from an Compressor Controller, but cant quite figure out what i am supposed to put into the...
133
Hi all. I received two identical brand new Dell desktops from a customer to install the softwares for a project. The first one is for a...
515
Hello, I'm struggling to learn something on Wonderware, and the distributors are taking days to get through the email chains. I was hoping for...
381
Hi guys, I facing some issue regarding the Historical Alarm settings. Currently my historian is configured as High-Speed storing method, and...
345
Hello everyone, After a Deploy of the viewapp on Intouch, I started getting an error not allowing me to start the viewer "NAD unable to download...
947
