T&B EZL500 wire marker Printer
VJTX
Oct 2007
TEXAS
126
Does anyone use the EZL500 wire label printer? I just wondered about the external power supply. The case says the shell is + and the center pin is -. Just wanted to verify. If you have the power supply would you verify for me? thanks.
Does anyone have experience wiring this type of analog pressure transmitter up? It's 4 wires. 3 blacks and 1 green which I assume is earth...
269
Hi everyone, I need some help I new with omron plc. I using plc CP1L. When I do the program it's good and the plc is function as program. But when...
86
Hi there, Trying to get some ascii serial communications working via RS485 (COMMREQ functions). I have attached our wiring for the COM2...
979
What's everyone use for I/O drawings on new installs. I am trying AutoCad Electrical, but can't download it due to a MS Office application running...
1,314
I've been tasked with adding a 3-wire pressure differential transmitter to a system and drawing up the wiring to an existing PLC board. The...
792
