T1000MD888+ (input problem)
billbryan
Jun 2006
BSB
hi there,
I'm newbie in PLC, I have T100MD888+ that I want to connect to a 12V cooling Fan. My concept is just to turned ON/Off the cooling fan via internet for DEMO purposes. My problem is when I run a very simple ladder to switch-on the FAN, is not working. then If I triggered the INPUT1 manually using a ground line then connect to power supply ground, then the light in the LED1 will activate then the cooling FAN will run.
Any idea is appreciated.
Thanks.
Bill
370
I'm having trouble calming down 2 Tempo Sonics. I'm using Studio 5000 CompactLogix my Raw value is jumping around from 8575.0 to 8755.0 at a...
30
1,145
I cannot add SLC500 analog input tag (I: 8.3) to EZSeries Touch Panel Editor (V 5.3). I used all the listed tag datatype but it all says "Invalid...
259
Hi, I have questions. I have Analog Input that need to put into Ignition Designer. But I don't know how to put?
119
Omron AD081-V1 Analog Input Card Offset & Gain Adjustment Entering Adjustment Mode 1. Set the input card in adjustment mode (Turn ON Dip SW No-1)...
88
