Td200c&s7-200
tulip
Oct 2005
ist
236
I have cpu221 rel 02.01 and td200c.I want to make alarm prog.I have 6 alarms inputs ( normally closed contact ) and 1 horn output.We make alarm reset on TD200C panel.I know this program is:oops: very simple for expert but We did not use microwin prog.before.
Any help would be great...
Hi
Here in the attachement you have a program for viewing Emergency Stops. I used the TD200 for that.
I did some scrolling text on it also, just to amuse myself.
I hope this helps you further...
I have a very simple requirement. I am using a siemens S7-200 with TD200 text display unit. The cable that connects both is a simple direct 9 pin...
10,212
hi ,,to all,,! respected members,,i want to share problem that i am facing,,hope u will help me,,! i want to add error code in td200c, can any...
1,424
Hi, I have a Siemens TD200C screen that displays a single character string. The user can edit this string, so the character displayed may be a...
2,602
Hello, I have a question about an encoder that has absolute measurement. Specifically, it's the Lika SMA5, which I would like to connect...
56
34
