Teco sg2 analog output
Graham773
Feb 2016
Windsor
This is my first time posting I have sg2 12hrd with a sg22ao module I have never programmed a analog output before and I was wondering if I could get some help
Timer 1 Dn output 1.5v to aq01
Timer 2 Dn output 3v to aq01
Timer 3 Dn output 4.5v to aq01
I know you have to write it to the data table I think it is drd0 and it registers it on drd4 and then outputs it to aq01 If someone could help me with this I would be thankful
It appears that you might be able to use mode 2 of the AR instruction to do what you want. It seems to support 4 analog output levels.
I have never used the 2AO module for anything so this guess is based entirely on what is in the manual.
Hello all, I am completely new to PLC programming and automation in general. I am working for a company that wants to use a TECO SG2 PLC to...
1,525
Hello - I'm sure this is a total rookie error ...but i've racked my brain and logged off/on, cycled power, substituted my final ladder program...
1,907
Hi, I'm trying to figure out how to use the SG2 modbus slave mode to both set a value in a register as well as set a single coil. It appears...
1,667
I have a TECO SG2 that when a link to the controller all is fine. When I try to read the controller I get "Commands do not match SG2 edit mode"...
3,382
I have programmed a timer into my sg2. It closes Q1 when it gets a pulse from I2, then as it gets pulses in from I4 it will subtract I2 from I1...
1,613
