Temperature Humidity Sensors
Mark Buskell
Sep 2003
Florida
892
They will both be measuring ambient temperature and humidity.
I will need to take the inputs into an 1769-L32. I have both
rtd and analog modules with enough spare.
Does anyone know of a device that they can recommend that has both types of outputs on one device or 2 4-20 ma outputs.
This is for an industrial type application so money is not the deciding factor. I did suggest they hang a thermometer but that got voted down. Go figure.
Any recommendations here?
For Industrial Applications I recommend http://www.rotronic-usa.com/prod_xmtr/hf5_main.html
Rotronic has some units that are a little less expensive and are still industrial quality. Check with your local rep.
If the operating temperature is room temperature, there are lower cost units that have both temp and RH, 2 wire 4-20mA outputs.
Both Vaisala and Rotronics have higher operating temp units too, but the price goes up with performance.
I am looking for temperature/humidity sensor recommendations. Would like the sensor to display temp and humidity. Need to connect to a Contrologix...
260
Does anyone know of a sensor/transmitter that is able measure humidity/dewpoint/water concentration in a stream of 1200F air?
3,442
Hello, Has anyone developed the relative humidity value by a temperature thermocouple? I also have pressure values. I have seen some formulas to...
1,997
Greetings, I've done some basic web searching and haven't been able to find what I'm looking for. I'm looking for a basic Temperature/Humidity...
10,219
Dear All Members, Could anybody help me? I have some problem. I need to show in HMI temperature and humidity can show. This is my device : 1. PLC...
8,307
