Temperature PT100
elkawafi
Aug 2002
27
Hi Every body
The PT100 is used to measure lubracation oil temperature and it connected to DCS through intrinsically card, but this sensor gives a spikes from time to time
Any ideas why this happen
Thank you all
Elkawafi
Maybe bad connections. Normally in a 4-wire system a constant current is sent through the PT100 via one pair of wires, while the voltage generated over the resistance by that current is measured on the other pair. If one or more of the wires shows a bad contact, you end with a lower measured value.
Sometimes a 2-wire PT100 is connected to a 4-wire system. It means you'll have to connect a current source wire and a measuring wire to each end of the PT100. If one of the connections has a high resistance (bad contact) then this could result in a measured value which is higher than expected.
Kind regards,
Is the cable screened and grounded at only 1 end? If not it should be.
Im having a 3wire pt100 connected to a temperature transmiter. Im reading the current in the loop and I have 22mA, so is overrange. What could...
1,711
Hello, In the module Simatic 6ES7 331-7KF02-0AB0, there are connected four PT100 sensors. All sensors show about 2 degrees too much (observed in...
2,077
How do major PLC manufacturers (Allen Bradley, GE, Siemens, etc.) get the temperature sensing signal for a PT100 or PT1000 into a PLC? Is there...
6,167
Hello to all, I need to wire total of 8 temperatures in SIMATIC S7-300 system. All probes are Pt100 in three wire connection. I suppose that one...
12,463
Hi All, I'm Quite new in PLC, Currently i have project which is Connect PT100 to Panasonic PLC FPX. How to connect the PT100 to FPX ? any FPX...
2,632
