Terminal Blocks for SS outputs
Brijm
May 2006
St. Marys, PA
645
Ran into another situtations, where I forgot to include resistors on a opto22 solid state output driving the input of a Moeller smart relay. The impedance of the inputs was too high, and there was not enough current draw, to completly turn on the output.... I had 120V on the input, but it did not register on the pico-plc.
So I was thinking.... Does anyone make terminal blocks, either that have leakage current resistors built in, or a termianl block, with a status light to draw the leakage current, and add a current draw, when the output is on. Either one would probably require neutral wire. I've never seen these, but think they would be useful when using solid state outputs, driving an electronic load.
Anyone know of a product like this.... I'm looking for something, that costs less than relays, and would be more neat looking, then resistors.
-MUR
Weidmuller has several terminal blocks with electronic elements. A diode or clamp might draw enough current and provide protection as well. They have some w/ 24 V LED that should be draw enough and give you a status light as well (but cost ~$7). You should check the relay's data sheet to be sure. My local rep has provided a sample gratis fairly quickly, to test before ordering.
I'm trying to include MOVs and fuses for solenoid PLC outputs in a panel with limited space. Does anyone know of terminal blocks that have built...
238
What is the difference between Siemens terminal block 6ES7193-6BP40-0BA1 and 6ES7193-6BP40-0DA1? Can they be used interchanged for an analog...
1,228
Currently using a AB 1492-FPK2, plug in fuse but now finding alot of these are.. touchy with connections. the terminal block they are plugged into...
1,359
OK, some internal "discussion" going on in my world about what is preferred in the industry for a three position connector, a spring clamp type or...
42
16,283
Hello, A couple of questions regarding NEMA schematics and terminal block labeling. 1) I am familiar with the DIN designations for components...
3,129
