Texas Instrument Plc / Proface Hmi
Dec 2003
GRENOBLE
I'm in touch with a potential customer which uses a TI 405 serie
CPU 425. He wants to buy a PROFACE panel to us but he don't know which
protocol is available on this CPU same for me after searching on internet.
Could you help me and give me the protocols available on this TI CPU.
Thanks in advance
I believe that TI 405 was originally a rebadged Koyo (or PLC Direct).
The TI brand is now under the Siemens umbrella, but only supported from the 505 series.
On this webpage you can see the possible PLC connections for a proface.
TI is not listed at all.
At Koyo/PLC Direct, only the CPUs D4-430 and D4-440 are listed.
At Siemens, only the series 505 is listed.
You seem to be out of luck.
But I would check with proface directly, they know best.
Thank you
I've checked with PROFACE France my supplier but no similar
application in the past with this TI CPU so ?????
I can't ask to Siemens people because we have some particular
relationship (we're VIPA distributors)
Best regards
The serial protocol for the TI Series 300, 400, and 500 PLCs was called Hostlink, and could be set up as either Master/Slave or Peer-to-Peer.
Don't take this as a fact without verifying it, but I think TI Hostlink is the same protocol as GE's CCM which was used for the Series One, Series Three, Series Five, and Series Six.
If Proface has connectivity with those old GE models, then you might be able to use the same driver for the TI 425 CPU. Note that it is not the same protocol as is used with the current GE Series 90 or VersaMax PLCs.
Upgrading an old TI PLC with a chassis PN 500-5840. has terminals on top and bottom but can't find a wiring diagram earlier. Help!! actually...
947
I have a issue with a TI 128 , i need someone to upload the program and download it to a repaired 128 i have purchased already. i am willing to...
2,368
I've had this problem twice with different customers in the last two years. We have repaired a Texas Instrument power supply for them a 500-2151...
2,323
Hello, I was wondering if anyone has any technical information about a Texas Instrument model # 500-5186 processor. I wound appreciate and...
1,583
Hi, Any body has TI 550 application (or equivalent) for up loading and maintenance of Texas Instrument PLC 530? Who has the stocked spare...
3,203
