The 8 Results of 2 Digital Input Commands
504bloke said:
But They are !
And i honestly believe that seimens are trying to take over the world! Buts thats another subject ;)
Well, I certainly wouldn't try and claim that Siemens make your life easy, but I do find that some enthusiasts for other manufacturers swear that their favourite system is so intuitive a 12 year old would get on fine with it. Sorry, I don't buy it, this is just the usual "what I'm used to/have worked with for "n" years is easy".
Actually, as a fugitive from the DCS world, my biggest problem is the cylical "Ablauf" - can't find a suitable English expression - process, operation, running system? I'm sure this problem will plague me regardless which PLC I'm using.
I'm not an electrician, I'm a Process Control Engineer. I'm happiest programming in SFC where I can take my Flow-Chart and translate it 1 : 1 into an SFC program. Translating a Flow-Chart directly into the cyclical Ladder, Function Block or even STL is an impossibility! I've never programmed using States, but I suspect I would get on with that OK as well.
If I can't use SFC, then as a previous H/W designer, I find Function Block most comfortable - reminds me of IC logic design, same applies to Siemens CFCs, the only time I use ladder is when Function Block produces something which covers about three screens and Viewing is easier in Ladder, which is usually a bit more compact. As far as STL goes, I get on quite well with that, perhaps as a result of many years programming PDP11s in machine code, however, that gets difficult as soon as Edges or Timers get involved!
I get the impression that the majority of the members here are electricians, at least by background, which probably explains a preference for ladder.
As far as logic goes I prefer TRUE and FALSE and I can't say I have ever seen anywhere in the Siemens documentation where they use NC / NO, there again the Siemens documentation is so extensive that I doubt I've read more than 5% of it!
RMA,
lancie1 said:
I checked my Siemens ladder, and it calls them "Normally Open" and "Normally Closed". The NO is okay, but the NC is a misnomer, a paradox.
Maybe it's because I'm using the German version but mine are calle TRUE and FALSE - yes, in English!
randylud said:
RMA,
Is Siemens still using the old TI mnemonics? I programmed a 5TI back in the day and seem to remember a Load, Load Not, or an LD, LD Not to examine the input status. Did not take a lot to get from there to XIC XIO
I've never used the 200 series, but I believe the S5 series also used to use the LD command for the first entry in a boolean logical structure in STL. With S7 that is no longer the case, boolean structures are described purely in boolean terms. In other words:
A M0.0
A M0.1
O M0.2
= Q0.0
Howdy guys - Looking for some insight on the MAM instruction. Had an interesting one today: I performed a controller upgrade on an older system...
459
Hi everyone! Accidentally closed it and it wont appear again. Checked and unchecked the option and seem to make no difference. Running v7.10.00...
1,977
Hello everyone, We have a vendor-supplied licensed RSLogix 5000 Professional Edition, Version 20.19. The vendor-developed program came with...
1,630
Hello. I have a problem which may be common in this part of the world. My CoDeSys program reads data from a text file that I generate from the...
2,480
  • Poll
Luckily, I do not have to worry about this test, but I am creating this poll for atc2222.
36
40,763
