The Easiest Way to Control Servo Motors
ZhongJiwei
Nov 2013
Singapore
18
Hi
i want to control three servo motors for just simple PTP moving with a touch screen or pc, due to the budget, so which is the best way to do it? Thanks.
ZhongJiwei
You say that you want the easiest way and that you have a budget.
How big is the budget?
I really doubt that arduino would be the easiest way. :)
There are system available pretty much done, just wire and run. These may not be the cheapest but by far the easiest.
Try an internet search of "Stand alone Motion Control".
The easiest way is to use a matching servo drive for the servo motor. But it's not the cheapest way.
You have easy and cheap. In this situation like most you can't have both. If it's easy it likely is not cheap.
If it's cheap it's likely not going to be easy.
Making complicated things like this easy to do costs money.
Be clear on which one you want.
P.S. Additional info such as motor type, Brand, Etc would be helpful also.
Good Afternoon , I have a few drawings I need to open up. I don't have Autocad. What is the easiest way to covert .DWG to .PDF ? Thanks so...
1,817
What should be the easiest way to control and view data from a Rockwell PLC using an Android smartphone without using pc? Can you suggest softwares?
3,739
Good Morning , We have a fairly large plant. I have some new machinery , that product is fed from some equipment about 400 to 500 feet...
3,547
What is the simplest method of clearing an array of integers in RSLogix 5000? I could make a zero array of the same size and copy it, but that...
4,810
