Thermocouple
Not enough info mate.
Give us as much as you can, including what you've done (programs, pictures, ideas, outcomes), hardware involved, what process you're controlling, accuracy required, thresholds.
The more you help us the less reluctant we will be to help you.
Normal you should use a PID, but as mentioned before, you give a very little information.
Most inportant, what is bandwidth between the lowest and highest temperature which your process need?
How many zones do you like to control?
Do you realy like to program a temperature control by your self?
Have you ever looked at the Omron Celciux? We use these units here in the factory to control nearly all our heaters.
I am having an issue getting a IY4 to read my thermocouple correctly. We have a R type and K type hooked up and sitting at a known room...
554
Posted by u/mr_biodtox 44 minutes ago Delta ISPSoft - Establishing communication with thermocouple module Hi, How do I establish communication...
344
Hi, We have an ongoing project with a lot of thermocouple involved that monitor the temperature of heaters. There are more than 20 PID...
32
3,506
Hello. PLC beginner here, so apologies in advance for any incorrect terminology or poor communication. I have an SLC 500 Thermocouple/mV Analog...
654
Hello Guys, Trying to scale a thermocouple directly into my IY4 card. Connected into the terminal +\-. I’ve scaled the range of my J type to...
1,689
