Thermsistors in water
What????
Well, yes if the leads are insulated so the electrical connections do not come in contact with the water. The body of the thermistor is often coated with a waterproof substance or can be bought that way. I do not know of any reason that you can not use a thermistor to measure water temps.
Usually a thermowell - essentially a water proof tube - is used to prevent direct contact between the water and the sensing element. These are standard items that can be obtained from most temperature sensing suppliers.
95
I want to measure the tank level and get the sensor output to the PLC. Below are the details : Tank Height =0 - 3m, the sensor is stalled 0,2m...
664
Hi, I am working on automating an industrial fabric shrinkage tester to replace its outdated electronics with a PLC. To get the tank's water level...
17
767
Hi all, i have an application in which i need to read the water level in a 1 1/2" diameter tube that is 24 in. tall. the sensor will be mounted...
27
2,005
Is it good idea to use ultrasonic clamp type of flowmeter for water dosing? I already using the flowmeter pulse output by setting to 10L per...
1,296
