Thoughs on relays, solenois, valves ...
BachPhi
Dec 2007
Los Alamos
640
In the manufacturing world, we deal with many devices like relays, solenoids, valves ....
Now, I know it's the first day of April and Trump is in the office, and being "green" may not be the buzz word in the current political atmosphere, but what if green also mean money saving? You can also carry on and on with continuous improvement ideas to your boss as well. it's win-win thing.
For each of these devices, we can put them into low power saving mode, and therefore we can typically save more than 60% of energy usage.
A penny here, a penny there, it adds up. Yes, lower power consumption is something to consider.
The solenoid valve manufacturer spent lots of money coming out with the Next Generation of solenoid valves whose claim to fame is energy savings, approaching the 0.5W level.
A couple white papers on the topic relating to solenoid valves:
http://www.asco.com/ASCO%20Asset%20Library/asco-low-power-valves-complete-catalog.pdf
http://www.asco.com/ASCO Asset Library/asco-optimizing-power-management-white-paper.pdf
The catalog is here:
http://www.asco.com/ASCO Asset Library/asco-low-power-valves-complete-catalog.pdf
The other place energy savings comes up is in valve positioners in process plants because most positioners continuously bleed instrument air. The Siemens PS2 uses instrument air only to when changing position, it uses none while idle.
I agree that there are measures that can (and should) be taken at the design level to reduce unneeded power consumption.
That said, I'm drawing a blank when attempting to envision how to put relays or solenoids into "power saving mode". If my process requires that solenoids and/or relays be energized, then I wouldn't consider reducing the voltage applied to their coils simply because they haven't changed states for the past 5 minutes.
Nice! I did not know about the new Asco power saving product. I wish the white paper describe a little more on the new switching circuit design. TI has a new chip DRV110 as recent as this month that doing the low power saving mode.
What I have not seen is some new boards that can do for multiple devices
You need to read the whitepaper to understand the basic underlying operation of electromagnetic devices.
If that is a concern, there are double-acting retentive valves as well as polarized relays long available on the market that do not require power being applied constantly to maintain the current state.
The downside: now you need two control circuits instead of one. And of course the usual considerations regarding what happens when the system loses power, how would it recover and so on.
"Green" is nice but always comes with a cost.
I thought it was pretty standard these days to have two stage solenoids in valves contactors and brakes? The switching is built into the device.
99% of the contactors I use these days are the DC electronic coil type - which means that they have an R/C network or similar built into the coil to provide for a big spike to pull the contactor in, but then have quite a low "hold-in" current. Not sure what it takes to pull them in, but once a schneider contactor anywhere up to 18.5kW is in, it only takes 2.4W to hold it there.
Hi all, looking to model old RR relays in PLC. Does anyone have any SPECIFIC examples on how to model a relay such as a polar relay, slow pickup...
95
I tried the click plus PLC to send emails today but could not get it to work over my network. I need a mass alert when a temperature reaches a...
431
Hey guys, the scenario is: I have already completed the drawing package for my system utilizing an A-B 440R-N23126 (Minotaur) safety relay. SoS...
166
I'd like to talk this through a little: Relays are regularly used for PLC outputs, regardless of a need for signal conversion. But what about...
972
Good Evening , I should know more about Solid State Relays . I have a system with 8) 120 vac Vibrators . These Solid State Relays have...
24
2,125
