Thoughts on Drum Winding System
bestbier
Jun 2008
Cape Town
26
Hi all
I am possibly going to be programming a drum winding system. This is a completely new system to me. I don't have all the details at the moment but here what I know:
2 x drums with cable driven by SEW motors and drives. The cable has to be wound between the 2 drums - when the one drum unwinds the cable the other has to wind up the cable. The distance between the 2 drums can be changed and the speed of the winding must be changable. Possiblity to expand with more sets of motors/drums and cable.
I can use any PLC but will probably go with Beckhoff.
Any ideas on this system will be appreciated. - like how the keep the tension constant.
Bestbier
This is a standard requirement in steel/paper/cable industries so I'm sure its well documented.
To keep the tension constant use a loop of cable over a sprung roller with feedback to give you the position of the roller.
I seem to remember you shouldnt have constant tension on the roll but have a tension profile depending on where you are on the roll.
Hi
Thanks for the input.
I have been thinking about it and think the best idea would be to have a big reel that only takes one layer of cable. That eliminates the problem with circumference of the reel getting bigger as it winds up the cable.
https://rockwellautomation.custhelp.com/app/answers/answer_view/a_id/1133982 What kind of hiccups could be expected before Rockwell puts out...
4,453
I was replacing a VFD today, and when I powered down the MCC bucket, the SCADA went into alarm (as I would expect it to). I acknowledged the alarm...
24
5,473
Called to a site and am neck deep currently ;) running, but issues. Phase 2 completion has been running for almost 2 years no issues. Controller...
1,641
Hi All, I am building a Profibus network using a Mitsubishi QJ71PB92D Profibus Master Module. Current Setup: - 1- Profibus Master (Resistor On)...
2,649
Good Afternoon , I have used many 1794-AENT Ethernet Adaptors , and never had this problem . I used BootP and assigned the IP Address , sent...
1,894
