Thread about laptops that support PCMK.
JesperMP
Feb 2003
ᚴᚬᛒᛅᚾᚼᚬᚠᚾ
16,338
There has been a number of threads recently about how to get PCMCIA cards in general and PCMK cards in particular to work with new laptops. This issue also interests me, since I have a laptop with a dead PCMCIA port.
I do know that you get a 1784-U2DHP that does the same, but as I see it, the cost of both 1784-PCMK and 1784-U2DHP is at least the same as the laptop itself. So it would mean a significant saving if you could get a laptop with a PCMCIA slot and that it actually works with the PCMK.
Also, I think that there is a problem with getting a PCMK card to work in the latest PCMCIA ports, as the PCMK card is 16-bit.
So I suggest that we post in this thread if we have found a comercially available laptop with a real PCMCIA port that is confirmed to work with the PCMK card.
(similar to the USB-to-serial thread from a couple of years ago).
I dont know of such a laptop myself, so I cannot start.
Dell e5500 has a real PCMCIA and a serial port
Works great with a 1784-PCMK /B
I have not had time to load my CP5512 yet.... I also need to load S7 :)
Hi Jesper,
FYI I have a Dell Latitude E6500 with a fully functional PCMCIA slot that works just fine with my 1784-PCMK series B. It does not have a serial port so I got the 9300-USBS for DF1.
Marc
Seems that e5500 has already been replaced by e5510.
Cryptically, in the specs it says "Cardreaders: 3-in-1-cardreader, 34 mm ExpressCard, chipcardreader or Type I/II PCMCIA (pc-card)".
If I try to buy one, the online dialog says "Latitude E5510 with express card slot". Cannot see how to set it up to include a PCMCIA slot.
e6500 has been replaced by e6510.
In the specs it says "6-i-1-cardreader, PCMCIA and ExpressCard 34". So I guess that this one is OK. Only problem is that it is quite a bit more expensive than what our IT department normally accept to spend.
Hi Again,
Yes, at least my E6500 has both express and PCMCIA slots.
I always explain to the IT folks that this is a tool used for making money. It isnt for email and MSword. Besides, tha damned thing has 10-15k worth of software on it!
Marc
PS the PCMK alone costs that much :)
Thanks GiT. The danish Dell-website looks slightly different. At least I know it can be done, so I guess I would just phone them to be extra sure that I dont goof it up.
"PC-Card" is a newer word for "PCMCIA".
My co-workers report that their Dell Latitude D6500 computers equipped with a Type II PC Card slot and XP SP3 do work with the 1784-PCMK/B.
I have a Dell Latitude D6410 that does not work with the -PCMK/B or -PCD. I have not tried a -PCC or a -PCMK/A.
I keep a Dell ATG620 specifically to run those interfaces, but I am investing in the USB/network interfaces because those work with Frontline Test Equipment's NetDecoder suite.
I'm going to start a project for work that will be time consuming over the next year or so. It happens to be a rental unit, so I'm not...
1,306
Hi all, I have an issue and I don't know how to proceed with it. So my problem is... I have several UDP connections. And all communication with...
20
4,330
In addition to our help with automation controls and troubleshooting, I suspect a lot of us have access to 3D printers. We can use these to help...
1,219
For a decade I've been around this forum, the new, first-time threads (in a log-in session) were display in bold typeface. The subject line...
22
7,944
Hey Folks. I had a thread a while back where we talked about the versioning issues that can arise with Studio5K. It has been determined that I...
2,450
