Throttle actuator
g.mccormick
Jul 2012
IN
961
I'm starting to piece parts together to build a genset. I believe I will be able to buy an Isuzu C223 engine that was originally in in a truck. The engine will have an automotive style governor in it. I will have to modulate the "throttle" to keep the engine running at 1800rpm.
Can anyone tell me where to find an actuator that would work? It needs to be fast response, so most electronic damper actuators are out.
This is a home project, so price is a big factor.
Just getting the engine, no vehicle with it. I've found genset speed controllers and actuators for around $500. I was planning doing the speed control inside plc, but could just use an actual speed controller system designed for gensets. Does anyone know how the throttle actuators are controlled for the genset speed control ssytem? Do they do a pwm signal?
In my conveyor system I have what we call a throttle back mode on a conveyor what happens is you can hear and see the belt speed up and slow down...
1,385
Hi all, I have what is likely a simple problem. My program says when 2 buttons (we can call them buttons A and B) are held for 1.5 seconds...
205
I'm looking for electric rotary actuator with field bus.
1,181
We are looking for using a linear actuator, with stroke of 780 mm, with force of 2000 to 10000 N, and powered by 24V. It has to be industrial...
890
Hi all, I have a tricky controls task to implement that I could use some input on. I have a system using a trap-screw linear actuator that...
42
12,691
