thumb wheels (how do they work)
May 2010
London
689
We have a very old Omron plc that has thumb wheels to enter data. (timers counters etc)
I have replaced some in the past and when I looked inside it just seemed to be different resistors.
We are now going to upgrade this plc and the gaffer still wants to use the thumb wheels as the people who use the machine are used to it???
Each one is wired back to in input but I cant work out how a differing resistance will give a different number value in the plc
All the thumbwheels I've dealt with in the past were just switches. Perhaps they're diodes or the resistors are part of some surge protection to make the contacts last?
Most thumb wheels are BCD switches. The switches have four outputs that give a binary representation of the selected thumb wheel digit. For more than one digit a BCD format is used. Each digit requires four discrete inputs.
For Ronnie Sullivan this can only be resolved by an analysis of the original wiring and program. Theoretically thumbwheel switches, if the have an individual output terminal for each thumbwheel position could have resistors in an R/2R format to provide an analog signal. Guessing won't help.
digital means for each thumbwheel one output
and for all thumbwheels 4 inputs
analog means for every thumbwheel one analog input.
or when using resistors one analog input.
just put your fluke on it and measure what happens when you turn a wheel.
If you are planning to use a display then i would consider to make them virtual. a panel with touchscreen costing about 750 euros complete with windows etc.
Happy Friday my friends. Does anyone have experience with Industrial USB Thumb Drives for the PanelView Plus 7 Performance. The ones that...
3,165
I had to get a new thumb drive for all of my Rockwell Software, (PV+ and RsLogix.) Do I have to create a Rockwell Software folder or will it do...
2,242
I was wondering, what would be considered the best rule of thumb when it comes to PLC scan time versus input speed time? An example would be...
2,545
Hi there Actually dont know whether shielded cable being used should be grounded on both sides or only at one side. Is rule same for both power...
7,875
Need recommendations and experiences with a really small thumb drive, and a larger sized one. Small one only needs to hold one program and...
5,423
rods87
R
