TI 500 Series Controller
ElCapitan1995
Jul 2003
I have an older model Texas Instruments 500 Series Controller (not the newer 505 series) of which I do not have a backup of the logic. It appears to have a RS-232 port that I can attach a PC to. Question is: What software is necessary to communicate with this device? I do have TISOFT 505 Version 7.1. Can I use that? I did not want to run the risk of accidentally erasing the program from the PLC by trying something I should not. I am comfortable with programming, but I am just trying to get the knack for proper interfacing with all the different brands of controllers out there.
I use both the 500 and 505 series controllers with TiSoft v5.0, using the same cable (9 pin to 25 pin adapter for the 500) without problems.
Instruments Series 500 Controller 530T-1104 Could anyone help!! I have a 3 Series 500 Controllers that require a routine battery change. The...
5,500
Hi all my first post here, well i have a TI 520c-1102 which lost its program and i have been ask to reload the program but i do not have a cable...
4,018
Anyone who can Help. We recently purchased two injection molding machines that have TI Series 500 - 530T-1112 PLC cards. These are my first...
3,891
I cannot add SLC500 analog input tag (I: 8.3) to EZSeries Touch Panel Editor (V 5.3). I used all the listed tag datatype but it all says "Invalid...
285
Hello, I have a 1764 1500 LSP Series A that keeps failing with DTL_E_FAIL I/O error. Searching around it seems there's a weird issue specifically...
121
