Ti 545
larrylolson
Jun 2003
Washington State
SET UP A TI545-TISOFT-IBM COMPATABLE-S232-WIN 98 PROGRAMABLE INTERFACE
ABOUT 10 YEARS AGO. SOMEONE STOLE THE PC. CAN ANYONE TEL ME THE DIFFERENT SETTINGS I HAVE TO SET TO MAKE THE PC TALK TO THE PLC?
TISOFT 4.2
Hello Larry;
I have worked with Tisoft from version 6, so there might be differences from version 4. But basically all you need to do is set the dipswitches on the PLC for the programming port speed; the sofware will adapt the Com port speed to connect through a null-modem cable.
You can get the system manual (and more) for the TI545/555 at:
http://www4.ad.siemens.de/csinfo/li...&nodeID0=10805067&lang=en&siteid=cs&aktprim=0
Hope this helps,
Daniel Chartier
I am working with a Siemens 545 PLC and the MODNIM Modbus module and I am trying to figure out if the module is a Master or Slave. It does Modbus...
1,821
What software and cable are used to program a Simatic 545? We have 3 on winders and need to make a small program change for a new product line...
1,835
Any old TI545 boys or girls reading this? Something I never figured out. We have one RS232 serial connection between our PC and the 545 Port 1...
1,344
Good day... Had a "boot" fault on display. Unplugged pump and when I plugged it back into power, the display is blank. I know that the unit...
2,032
Hello Long time lurker. I am flailing around trying to figure out how to implement MODBUS TCP on a W2000 IPC that controls one of my company's...
5,924
