TI505 TiWay vs. Peerlink
Von
Jul 2006
Florida
50
Can anyone briefly describe the difference in/between the TiWay and Peerlink networks.
I have inherited some old TI505 control systems that employ both "networks" simultaneously. With no documentation (yet found) and very little physical site investigation (so far), I'm hoping someone can give me a primer on the applications or differences or why both are required.
TIA...Von
Goto: http://www2.sea.siemens.com/Products/Automation/Programmable-Controllers/Programmable-Controllers-SIMATIC-505-Manuals
A rather simple explanation is TiWay connects a PC for SCADA or programming to multiple TI500/505 PLC's. Peerlink connects multiple TI500/505 PLC's for data exchange.
I haven't used TiWay but had one system with a TI545 and TI525 Peerlinked for data exchange. The Genesis MMI was connected to the TI545 via serial port. The comunication was quite reliable.
I'm sure the more experienced guys out there can give you more in depth information.
Just as the man said.
Tiway was a hosted system, (host = PC or equivalent) and all the PLCs were 'secondaries' on the network. They could never initiate comms and only responded to message or requests from the host. Data exchange between PLCs was only possible by the host reading from one and writing to the other. If the host died all network traffic stopped.
Peerlink was a subset of Tiway using same electrical specs and cabling. No external host - each PLC was its own 'host'. Here up to 16 PLCs could be connected together in a token-passing system. Each one took it in turns to broadcast a small set of data (16 words max.) to all the others on the network. If one or more PLCs died every one else just carried on until there was only one left. Cut the cable, and then you could have two seperate networks chugging away! Very easy to set up and very resilient.
regards
Ken
Hi. I have 2 files where I would like to see the ladder logic differences (similar to the Rockwell compare function). I am using TISoft Siemens...
1,282
Hello everyone, this is a noob speaking. I have no idea about plc's, just some basic things. So, I work at a factory in greece and we have a...
1,155
I am trying to figure out the math with two U16 values that are converted to a Float(F32) in the TI so as to duplicate in a Siemens S7-1500. Seems...
2,105
Stick a fork in it? Circa 1995 control system on a critical machine. Less than 100 Digital IO, less than 10 analog IO. I believe we can remove...
1,676
Hi, I'm in an plant that uses TI505's. They have started upgrading to compactlogix but have reached the stage that they need PLC to PLC coms. TI...
2,350
