TIA Portal: change tag value
ASF
Jun 2012
Australia
3,921
Hi all,
I've got what I'm sure is a simple question about TIA portal, but my AB brain just can't work it out.
I'm online with an S7-1200 using TIA portal v11. I have a couple of REAL tags (members of a data block) whose values I want to manually manipulate in TIA portal. Nothing is currently writing to them - they're settings, which can be changed from a HMI, but otherwise remain the same. In AB world, it's as easy as "monitor tag" and typing in a new value - or even just typing the new value into it in the ladder editor.
In TIA portal? Can't for the life of me find a way to do it. I can monitor the data block, but I can't see a way to change it. I can add the tags to a force table, but I can't force them. I can see the values in the ladder editor, but I can't find an option to change them. Can anyone put me out of my misery?
Ah, watch tables...didn't think of that! I've left site now but will give it a shot in the morning. Thanks!
And when it is used, while watching ladder online, you can right click and "modify value"...
I am working on a PLC program that requires an analog valve to close a given percentage in a given time in seconds. I give the start position, the...
22
2,965
Hello guys, I use Tia Portal V16. What is the best way to change the indexed HMI tags when I change the format of an Udt in my plc program...
1,310
Hi, I have a Siemens Comfort panel HMI with datalog setup at a remote site and I have been given CSV data from a client for analysis of the log...
4,391
Hello everyone, Who knows how to implement constants in CASE loop via address to do it flexible. I show it on screenshot. Thanks a lot.
53
15,814
Hi! I have downloaded sample functionblocks from Siemens, they are know how protected. I want to use four of these function blocks. Problem is...
4,471
