rQx
I have all my program in OB1 with FCs and FBs, taking up apporx 45 networks.
If I add more program cycles for example 123 and 124.
I assume that the program scan will be OB1 ->OB123->OB124?
Can I delete OB1 or does it have to be there?
I wan't to structure my programming a little bit more so the networks that aren't used as mush in the programming and fault finding will be moved to other OBs and left in my "main" OB will be the core of the machine.
Also, bonus question: I have set up three DBs for HMIcontrol, HMIsettings and status. Would you set it up in one DB and using STRUCTS to divide them, haveing one large DB or is smaller DBs to be prefered? Maybe also smaller DBs then I have? HMIsettingAutomaticmode, HMIsettingHandmode etc etc
/Tim
/Tim
