TIA Portal V13 user data type
Jurgens85
Nov 2014
Veluwe
Hello Guys,
I'm using Wincc V13 in the TIA portal environment. With the configuration, s7-1500 PLC and TP1200 HMI. In the PLC I have an DB filled with UDT's.
I've tried to add a tag to the HMI, which is an UDT in the PLC. I want to connect the tag to a faceplate. But when I am adding the tag, I have the following failure:
I have read something about WinCC RT Professional, does somebody have the solution, or got this to work?
Regards,
Jurgen
You need to recreate the UDT as an HMI structure. Just like you created the Faceplate in the library, you also need to create the structure there. if you make it matching the PLC UDT, then it should all work.
I would hope they can figure out how to unify things in a future release, but you need to create the same structure in both sections for now.
I'm not sure if there are additional requirements on using optimized vs standard DB's linked with structures in the HMI. I haven't used them much.
I am working on a program that was developed in 2015 for an S7-300 safety PLC. The new copy of this machine uses an S7-1500 safety plc. We were...
1,913
Hi Guys, Please, I'm in need of TIA Portal v13 SP1 The V13 I saw can't open a Comfort panel HMI file. Can any one help? It will be much...
5,455
TIA Portal V13 with 1515 Processor. TIA Portal being run on VM. For many weeks, was able to go online and monitor blocks while troubleshooting...
4,012
We had hard drive failure and lost our most recent backup of one of our TIA Portal V13 projects. I uploaded the current program from the PLC...
4,254
Hi, I try almost everything but not solve the problem. As attached is the screenshot of the error from Tia Portal, There seem problem with the...
4,122
