TIA Portal Version 15.1 and 15" Comfort Touch
plcengineer
Jan 2004
USA
176
I am working on a project that will have a S7-1500 tied to two 15" Comfort Touch HMI's. I established communications to the HMI today and I can turn on the LED.. I dropped a PLC Tag on my root screen and then when I compiled the project, I tried to download to the HMI. The download failed with an error, you must compile before downloading.. I did that but it doesn't seem to work.. Does any one have any ideas?
Also, I am replacing an old TI-555 and with Profibus Communications along with two FIM modules.. The system also has a Wonderware Intouch HMI..The S7-1500 coupled with the RS422-485 cards will replace the existing system.. The serial cards communicated to Siemens Drives via USS, I think..I found out that it is not worth trying to convert old TI to S7 so I am going to just try to duplicate the existing code. I am not really sure how to use communications to the drives with these new cards.. Does anyone have any literature or pointers on how to send-receive data to these drives?
I am relatively new to this TIA Platform..
Thanks,
Try to force a complete recompile, right click the HMI and recompile HARDWARE, after that SOFTWARE ALL.
If any errors come up, you can see them in the info tab on the bottom.
New with just TIA or Siemens HMI's in general?
This is THE golden rule when working with Siemens HMI's, it'll save you hours upon hours upon hours of frustration. You better make this a habit now.
Always and I literally mean ALWAYS do a Rebuild All before downloading. In TIA it's right click on device in tree menu on the left > Compile > Software (rebuild all) (or hardware if you've changed HW settings)
Siemens has had issues with just normal compiles since WinCC Flex 2004, since before they patched in the Rebuild All function.
And another thing I've had to learn the hard way with TIA: If all else failed, reboot your PC.
Try to describe the existing setup (before the intended conversion) in details.
Please specify the exact type no's of all the relevant critical parts.
What are the Profibus IFM modules used for ?
If the TI code is in Ladder, then just manually copying to similar Ladder in S7-1500 will be reasonably straightforward.
But even then, a conversion job from TI to S7-1500 sounds as a big job for someone new to TIA.
It sounds like the compile didn't succeed. What errors did the compile have? There should be a tab on the bottom with compile related info.
On the plus side, it should automatically compile before the download. The downside, as others have mentioned, if you don't manually do a "compile all", the standard delta compile occasionally misses things. I don't compile all every time, but it is the first thing I do when troubleshooting.
Also: note that for whatever reason PLC compiles prevent Portal from doing anything else, whereas HMI compiles appear to be multithreaded, and let you click around. HOWEVER, many actions (like something as simple as saving) cancel the HMI compile.
JRW, Please see the attached PDF for the existing system layout.. I will get the exact drive numbers when I go back to the plant.. The drives are late 90's DC Drives with Profibus and USS protocol Communications..
We are upgrading to the S7-1500 Platform... We have a 9 pin connection on the old FIM Modules and we ordered a 15 pin cable to mate up to the new comm cards.. I need to look at how I can convert the 15 pin to 9 pin so that I can keep the old system in place until the new is running..
1 1 6EP13324BA00 SIMATIC PM 1507 24 V/3 A Stabilized power supply for SIMATIC S7-1500 input: 120/230 V AC, output: 24 V DC/3 A
2 1 6ES75163AN010AB0 SIMATIC S7-1500, CPU 1516-3 PN/DP, Central processing unit with Work memory 1 MB for program and 5 MB for data, 1st interface: PROFINET IRT with 2-port switch, 2nd interface: PROFINET RT, 3rd interface: PROFIBUS, 10 ns bit performance, SIMATIC Memory Card required
3 2 6ES75411AB000AB0 SIMATIC S7-1500, CM PTP RS422/485 HF Communication module for Serial connection RS422 and RS485, Freeport, 3964 (R), USS, MODBUS RTU Master, Slave, 115200 Kbit/s, 15-Pin D-sub socket
4 1 6ES75901AC400AA0 SIMATIC S7-1500, Mounting rail 245mm (approx. 9.6 inch); incl. grounding screw, integrated DIN rail for mounting of incidentals such as terminals, automatic circuit breakers and relays
5 2 6ES79023AB000AA0 SIMATIC S7/M7, cable for point-to-point connections RS422-RS422 15-pole D-sub pins respectively 5 m length
6 1 6ES79548LF030AA0 SIMATIC S7, MEMORY CARD FOR S7-1X00 CPU/SINAMICS, 3,3 V FLASH, 24 MBYTE
HMI
7 1 6AV21240QC020AX1 SIMATIC HMI TP1500 COMFORT, COMFORT PANEL, TOUCH OPERATION, 15" WIDESCREEN-TFT-DISPLAY, 16 MIL. COLORS, PROFINET INTERFACE, MPI/PROFIBUS DP INTERFACE, 24 MB USER MEMORY, WEC 2013, CONFIGURABLE FROM WINCC COMFORT V14 SP1 WITH HSP
8 1 6AV21818XP000AX0 SIMATIC SD memory card 2 GB Secure Digital Card for For devices with corresponding Slot Further information, Quantity and content: see technical data
Software
9 1 6AV21010AA050AA5 SIMATIC WinCC Comfort V15, engineering software in TIA Portal; floating license; software and documentation on DVD; license key on USB stick; class A; 6 languages: GE,EN,IT,FR,ES,ZN; executable under Windows 7 (64 bit), Windows 10 (64 bit), WinSrv 2012 R2/2016 (64 bit) for configuration of SIMATIC Panels
10 1 6AV66120AA000AL0 SIMATIC WinCC Comfort Software Update Service within the framework of this contract, you will receive for one year all up-to-date software versions. the contract is extended automatically by 1 year if it is not canceled 3 months prior to expiration. Period of delivery and service: 1 year from date of invoice Requirement for conclusion: current version of the software
11 1 6ES78221AA050YA5 SIMATIC STEP 7 Prof. V15 floating license; engineering software in TIA Portal; SW and Docu on DVD; class A; license key on USB stick; 6 languages: GE,EN,IT,FR,ES,ZN; executable under Windows 7 (64 Bit), Windows 10 (64 Bit), Windows Server 2012R2 (64 Bit), Windows Server 2016 (64 Bit); for configuration of SIMATIC S7-1200/1500, SIMATIC S7-300/400/WinAC SIMATIC Basic Panels
12 1 6ES78221AA000YL5 SIMATIC STEP 7 Professional Software Update Service (SUS) for STEP 7 in TIA Portal; within the framework of this contract, you will receive for one year all up-to-date software versions. the contract is extended automatically by 1 year if it is not canceled 3 months prior to expiration. Period of delivery and service: 1 year from date of invoice. Requirement for conclusion: current version of the software
Do you have the drive part number and a drive topology layout?
I don’t see a reason to have USS and profibus on the drives (if there is indeed both on them)
Here are the part #'s that they sent me.. I know that they are late 90's Siemens DC Drives.. They do have Profibus and USS comms to them.. The 505 PLC communicates Profibus-DP to all the drives in a daisy chain and the 505 FIM Cards communicate USS to the drives as well.. The PDF I posted shows the architecture and the JPG attached here shows it as well..
Extruders and melt pumps
B EXT A1 116-210-511
AEXT A1 116-210-505
CEXT A1 116-210-505
DEXT A1 116-210-506
EEXT A1 116-210-506
A Mpump A1 116-250-503
C Mpump A1 116-250-503
D Mpump A1 116-250-503
E Mpump A1 116-250-503
Line drives
Cast 1 A1 116-250-504
Cast 2 A1 116-250-503
MDO 1 A1 116-250-504
MDO 2 A1 116-250-505
Fast Draw A1 116-250-505
Coater A1 116-250-503
Slitter A1 116-250-503
Tenter A1 116-250-111
Reduce the picture size to 550x750 or zip and attach the zip file.
I find it odd that there is both USS and Profibus to all the drives.
Is it possible that they started with USS and switched over to Profibus at some time ?
Again, please post exact type numbers for all the drives and eventual communication cards on the drives.
Hi, I have had problem with upgrading some projects from v16 to v18. I tried it on 3 diffrent computers. I want to post this so that anyone that...
176
My PLC (S7-1200 with CPU-1212C) has now been delivered to customer site. They've asked me to do some updates to the software. I can do that on my...
21
496
I'm looking for someone that may have a download file of TIA Portal V14 and 15. I have a customer that has 2 PLCs on is a 1212C with firmware 4.5...
3,296
I have a db that must be optimised due to the size of the data in it. I would LOVE to switch to non optimized but then the db max size limit is...
5,147
Hello, I have a PLC programmed in TIA Portal V12. HMI for this system was also created with V12 but it broke and I was forced to upgrade project...
2,882
