TIA V13 -> V14 issue
boneless
Feb 2008
OKC
1,628
Hi all,
Recently we updated a couple of projects to TIA V14, and it all worked great.
But now I am trying to change one of our standard F-FB's and get the attached error message. A quick google turned up nothing. Any of you guy's seen this before?
Yeah, I can compile the project in V14 as well. I can not change any F-blocks that are in the project library. Just tested with a new block, aren't able to add a new block to the library either.
Seems we have found a bug.. Co-worker brought this up today, already talking to Siemens who are checking.
Edit: Just tested if I can change and compile an F-FB. I can still do that. The problem lies in releasing it to the library. Project library that is.
Latest versions of everything as far as I know. Like I said, I can edit and download without problem.. The issue is saving to project library (or adding to)
Same error for both.
Thanks!
Thanks for checking Sigma, the issues I have are in V14 only.
I don't think that there is any write protection inside of the project library, since I can change non F blocks.
It's the same number, same text, but for the title.
Yeah I agree, I will let you know what Siemens has as an excuse :)
Thanks again Sigma!
Hello Guys, I am newbie to siemen's software. I have project file from TIA v13 which I want to open from TIA v14. All software are up to date...
3,106
Hi all, I've just received version 15 of TIA Portal. The blurb on the Siemens website says... We have software that we want to continue to use...
20
33,358
Hello, Just exported a working FB to an external source in Tia v13. Tried to import it by generating the source in Tia v14 and the block cannot...
1,865
I am working on a program that was developed in 2015 for an S7-300 safety PLC. The new copy of this machine uses an S7-1500 safety plc. We were...
1,903
Hi Guys, Please, I'm in need of TIA Portal v13 SP1 The V13 I saw can't open a Comfort panel HMI file. Can any one help? It will be much...
5,424
