TiaPortal how can i change a text in the screen from the screen and save it?
thewalkerist
May 2021
Izmir
178
Hello everyone,
I am currently trying to build a HMI(KTP400 basic) for myself. I have some UDT data and use these UDT data for 20~ fruit/vegetable types and they all share the same variables but these variables will have different value in every type of fruit/vegetable. Now i created a screen for the two of these Fruits/vegetables and named them "Preset 1" and "Preset 2".
When i click the "Customize" button a new screen comes out with my variables so that i can edit them. But i want to add the option to change the name of the preset so that i after i am done with my editing i can change the name of the "Preset 1" to something like "Potato Setting".
And after i change the name to Potato Setting from the editing screen i want the name of the setting to change in the previous screen aswell.
How can i do that?
I thought of maybe adding another variable and name it "Preset_Name" then i can call it from anywhere i want but i still dont know how to change it though
Ok so i think i am on the right track here. So here i created 2 new variables and named them Preset_Name and Preset_Number. Now i'm gonna use the Preset_Number to identify which preset i am at(still gonna figure that out :D) and im gonna use that Preset_Name to store and change my names for my presets.
So my preset name will be the same as my other variables. Im gonna change it whenever i want to and im gonna use I/O fields to see which preset im at. But this sparks another question for me though. I know that Preset_Number will be my only constant that will never change. And i know that i will use those values to change my variables. But i dont know how.
I guess after i press the button to change preset i will use move blocks to change the Preset_Number of the Preset[0] and im gonna use comparators to check for the preset[0]'s Preset_Number and if it is equals to lets say 15 then im gonna move every variable to the Preset[0]. Preset[0] is my execution Preset of sorts.
I dont know what happened but i guess i solved the problem while i was writing about it :D Im gonna see if this works or not and im gonna update you guys about it later
And wont i have to put every single one of my 200 values into the recipe window? Cant i just shove my entire data block in there somehow :D
OK so from what i understand(Looking up about them right now), i dont need to have like 200 different values. I just use the original 10 values and with the help of the recipe view i can add, delete, see and change the name/values without creating additional tags. This is amazing.
Hello, I am currently trying to control a motor in my plc. I've made a simple on/off button logic. And it works pretty well, when i press the...
25
6,141
Does anyone know if there's a technical reason why Siemens HMIs can't have the program uploaded from them into TIAPortal as a project file, or is...
807
I have a nice project in Visilogic that I have been asked to re-create in Tiaportal/Siemens. (Bosses / maintenance want to standardise on one...
1,333
Hi All, which the best way to do the indirect addressing in an optimize DB? Ccurrently this is my partial code inside an FB...
2,311
Hello everyone, I dont know if this is a common error or if im wrong but whenever i create a screen i am allways afraid of my life with this...
2,093
