Time counting down-need help!!!
karlag
Mar 2006
Canada
81
Hi ,I need your help. I have Mitsubishi FX1N and GT-11 Nais screen and I have to show time counting down on the screen .
May be someone knows how to do that?
Thank you!
just subtract accumulated time from preset.
without trying on a real plc i'm not sure if you can
subtract from timer directly, maybe MOV instrution is not needed...
You can have preset hardcoded, but it might be good idea to use
register like D0 so you can adjust it any time.
Hello, all! Maybe someone had the same problem? I use the Rockwell Automation software. I need to make 24 hours timer indicator with minutes on...
1,811
Hi, I am wanting to know if this is possible using S7: When a 1 hour timer has been triggered (count up timer), to detect when the 1 hour timer...
2,155
How do I make a counter that will count down from 10000 in step 7.The count down counter can only count down from 999,right??? So how do I do...
25
5,664
Hello I am looking for tips on how to count the duration of a given function and then how to display it on the hmi panel in the hh:mm:ss format...
1,703
Guys, I know it will be silly but can't get my head around it. I have 3 conveyors, every one on a separate servo drive, and 2...
25
3,506
