time shared co2 control
soya
Mar 2007
DIBAI
can any one help me out?
I have 20 cooling rooms with co2 control.co2 control is done through opening and closing of a damper.and i can give damper on and off to maximum 2 rooms.now my idea is to give a particular time for each room regardless of reaching setpoint(co2) ,if request queue (ie for morethan 2 rooms) is there.
i am using slc 5/04.......any suggetion is appreciated.
I have no comprehension of what your system is doing.
Are you controlling air conditioning of a meeting room using the carbon dioxide concentration?
OR
Are you injecting CO2 into a room?
OR
Are you using CO2 to provide cooling to the rooms?
Dan Bentler
Hello all. Is it possible to create a shared folder between my laptop and my PV+ 7- standard......2711P-T10C21D8S Series D? What I would like to...
444
Hi All, i'm upgrading a [3x] GE 30-90 system that extensively uses %G Global Genius Tags via Genius bus. This is changing to RX3i (CPE310)...
576
Hello, is it possible to create a data block, something like shared datablock in Siemens STEP 7, in the RS Logix5000 PLC project? I would like...
1,073
Hello CODESYS experts, once again I need help. Trying to setup a PROFINET device which supports shared device function, has four (4) IO modules (2...
896
I'm working on a project using a few kinetix 5500 drives, and I can't seem to get a straight answer from co-workers on power setup. I know you...
1,738
