Timer.Pre Value setup
learner
Apr 2007
British Columbia
81
Aside from using a For loop. what is the fastest way of setting the Preset values of timers located in the an array of 200? all the Preset values will be the same. I just want them to be set on the first scan to make sure nothing is missing.
Rslogix5000
Rslogix5000
Does it matter about speed if you are only executing it once on first scan ?
I would personally go with the "brute force" method, setting them individually. This will allow modifications later if some of them need to be a different preset.
Don't know if this will work, not at a PLC at the moment
Steve
Sorry should be 200
val1 contains the preset value
I have some logic that I have written within a 5380 series controller that tracks the time an event is started, while the event is running an RTO...
102
Hi all, I have a simple question that I have overcomplicated and gotten stuck on. I have a variable, we can call it "light" that I need to stay...
345
Question to anyone with ideas about my thoughts on upgrading a very vintage timer, which is being used to switch between 2 5hp domestic water...
451
why my timer only executes once here? After first time i use it, ET stays at 0ms all the time. It is in FB
322
Good morning guys, I'm searching for a Timer relay which accomplishes the "flasher" condition in the photo attached, however, I need the ability...
560
