Timers and counters
annicat1
Mar 2013
Adelaide
Good evening. I need your advise in regards to some tasks that I have with ladder logic & mnemonic code. The tasks are:
1)ladder logic to energize the output 1 one minute and 5 sec after input 1 is closed. answer: LOD 1, TIM 1 (set for 1 min 5 sec=650),LOD TIM 1, OUT 1
2) design a ladder diagram for start/delta motor starter using a 3.5 second delay from start to delta. star and delta contactors must not be energized at the same time. izumi controller addresses: start button 1, stop button 2, overload 3, main contactor 200, star contactor 201, delta contactor 202. answer: need to use timer as well and NC contacts in order to prevent star and delta contactors energized at the same time.But need help with the logic.
3)A large 3 phase motor has a restricted duty cycle and must not be started more that 5 times in 1 minute. Develop the logic to accomplish this starting motor DOL. should the motor be started 5 times within 1 minute, then it must not be able to started again until a further 2 minutes have elapsed. answer: need set counter to 5 and have delay timer for 2 minutes. But need help with the logic.
welcome to the site
design on paper will help you
you already will know the Star/Delta hard wire control
as the Star contactor has to both energize first you can count the number of times it starts and delay the time until the next start can occcur
start programming and Post either a snapshot or zipped copy of the program as far as you have gone - with IZUMI it might be better to use the SNAPSHOT function
https://www.youtube.com/watch?v=zTOOYWMJg9M . Specifically see 1:46 to 2:11. 3. The Cell PLC is in constant communication with two other field...
3,178
Hello everybody, I'm searching the product of GE Rx7i family and also Allen Bradley ControlLogix 1756 series to find the number of timers and...
1,570
I am looking for ideas for implementing a logic to monitor vibration pulses using timers and counters. I would like to count every pulse greater...
2,697
I'm using PC Worx and am trying to program something to keep track of the time a particular product is operational using years, months, days...
2,809
Hello, I have a stupid questions How many timers and counters we can have or can we create more timers and counters ??? For example in...
19,161
