TIMX and CX-programmer
Boyko
Oct 2005
26
Hello. Can you help me?
TIMX instruction does not work for me. I'm using CJ1M-CPU11 with CX-One.
When I type TIMX 10 &50, CX does not accept it. So I was constarined to use the BCD timer, i.e. TIM 10 #50.
I don't like the BCD, I prefer the BIN and every my const and var is BIN (&).
I can't see any advantages of using the BCD. Why I've to store a value from 0 to 9999 when I can store 0-65535.
Thanx
Hello Boyko,
Have you set the PLC properties to BIN Timers and Counters?
Right click on the PLC in the project workspace and select 'properties' from the pop-up menu.
There, you'll find a checkbox - 'Execute Timer/Counter as Binary'.
Check it, and away you go...
Hope this helps.
Just trying to use a variable to change the SV on a timx timer. Im using a hmi to input a minute value then I times that by 600 to get the right...
2,014
bonjour je souhaiterais savoir si c'est possible de faire communiquer Cx-programmer ( logiciel de programmation des automates Omron ) avec...
157
Dear All, I need a sample PLC program to count the output pulse of a mass flow meter so that a specific amount of mass (for example 100gm)can be...
158
I need a good website or tutorial to learn plc programming Thank you
511
Hello ! I am trying to use an omron cj2m-cpu33 with a CP1W-CIF01 plug in serial connector to talk to a zebra ZT610 printer. I am getting the data...
383
