Torque follow 2 servos with Kinetics 6k?
prs1025
Apr 2008
Midwest
Hi. I have an application where I need 2 servo motors that are mechanically linked to run a gear box (motor A is connected to motor B via 2 independent shafts and an idler gear). This is a ControlLogix system using Kinetics 6k drives with a 1756-M16SE card in the rack. Also, the gear box has to run at a given velocity. It's not position dependent.
So I'm wondering what is the best way to do this. At first I was thinking to have motor A geared to motor B (both in velocity loop) and just limit the torque on motor A. Or possibly even gear both to a virtual axis. But now I think a Torque Following type of solution would be best. I know that Torque Following is possbile when using VFDs but I don't know how to do this with ControlLogix and Kinetics 6k.
Any helpful ideas would be greatly appreciated. Thanks
Hello, I have a motor that we are sending a RPM Speed Output from 0-100% to the VFD. However, the Motor HP needs to be limited to 6000 HP and the...
112
I have always controlled servos in Rockwell motion using position loop. I have an application where one process will push against a servo...
302
Hello, Would anyone happen to know what parameter in a PowerFlex 525 to have the drive trip if the torque permissive set point is exceeded...
482
Possible dumb question here, but how does running a motor through a gearbox effect a VFDs ability to limit the torque on the driven load? My gut...
546
Hello, I am posting this question (regarding drive control) on this PLC forum because I see that there has been discussion regarding this issue...
640
