torque for dummies
Apr 2002
Just a bit northeast of nowhere
1,117
Yeh, I'm a torque-dork. Trying to get my mind around what a torque rating actually means in the real world without getting all greeky about it...
So a motor is rated at 10 pound-feet of torque. Please check my assumptions:
1. At 1 foot distance from the center of the motor shaft, 10 lbs of force are generated.
2. At ten feet from the center of the shaft, 1 lb of force is generated.
3. At 6 inches from the center of the shaft, 20 lb of force is generated.
I'm not speccing something specific here, I'm just looking for a rule of thumb, so I can go on to develop more intelligent questions.
Thanks,
TM
You have the basic understanding of 10 lb*ft. of torque.
Of course, when it comes to motors, there is a little more to it as the torque output will vary with the speed and with the way the drive operates if there is one.
What type of motor are you talking about?
Thanks, TM
Non geeky response - you got it. So far
Now for the parts that threw me for a loop for several weeks
1. Constant torque load (conveyers cranes etc). Assuming the LOAD is constant (ie pounds on crane hook) how can torque be constant with increasing speed?
2. IF The motor torque is greater than the load torque the motor can accelerate the load. IF less the motor will slow.
Two was pretty obvious but I had XXXX of a time getting my mind around #1. Still have to think on it sometimes. Sure will be nice when it is automatic.
Dan Bentler
Two important concepts.
First, a motor's rating defines its capability. It doesn't define its output - the load does that. The example I like to use: If you put the blade from your bathroom vent fan on a 300 hp motor, will the motor output 300 hp? Of course not!
Second, hp is a funtion of time and speed. In US customary units hp = lb-ft_Torque x rpm / 5252
So, with a conveyor or a crane you have a fixed load pulled over a fixed radius winch or headshaft pulley. Since T = F x r you have a constant torque. (Assuming the torque is within the motor's ratings, of course.)
If you increase the speed the load and the pulley radius don't change, so of course the torque can't change. Remember, the load determines the torque, not the motor rating! However, intuitively you know that at a faster speed something has to change, and you are right! Although torque is the same, power increases at the higher rpm.
From Chapman handbook:
The torque on an object is defined as the product of the force applied to the object and the smallest distance between the line of action of the force and the object's axis of rotation. If r is a vector pointing from the axis of rotation to the point of applicalion of the force, and if F is the applied force, then the torque can be described as:
Torque = (force applied)(perpendicular distance)
= (F) (r sin (a))
= rF sin (a)
where (a) is the angle between the vector r and the vector F. The direction of the torque is clockwise if it would tend to cause a clockwise rotation and counterclockwise if it would tend to cause a counterclockwise rotalion.
The units of torque are newton-meters in SI units and pound-feet in lhe English system.
= (F) (r sin (a))
= rF sin (a)
geek version o_O
Clay B.:
LOL, sorry I thought it was going to be an easy explanation.
No problem... I just saw the funny in it... As Peter said when you get to motion control the geek version is important.
The non-geek version works when your doing conveyors and other basic motor funtions...
FYI...Peter invented the geek version...:ROFLMAO:
Hello, I have a motor that we are sending a RPM Speed Output from 0-100% to the VFD. However, the Motor HP needs to be limited to 6000 HP and the...
107
I have always controlled servos in Rockwell motion using position loop. I have an application where one process will push against a servo...
293
Hello, Would anyone happen to know what parameter in a PowerFlex 525 to have the drive trip if the torque permissive set point is exceeded...
462
Possible dumb question here, but how does running a motor through a gearbox effect a VFDs ability to limit the torque on the driven load? My gut...
542
Hello, I am posting this question (regarding drive control) on this PLC forum because I see that there has been discussion regarding this issue...
628
