Toshiba PLC Wonderware help
mcalidl
Aug 2006
Birimingham, AL
50
We currently have 5 T2 toshiba plcs running our line. I am wanting to put a WonderWare HMI on the whole line for easier troubleshooting. The problem is I am not familiar enough with the Toshiba product to do so. I am an allen bradley guy that is used to Wonderware and RSLinx. All of the current allen bradley projects have a wonderware application running over ethernet. The Toshiba T2s do not have ethernet capability only a RS485 and RS232 port. Before me, someone bought Lantronix RS485/232 to ethernet adapters and then left the company and I am not sure if they had any success or even tried to get them working. But I am not sure even where to get started. What do I need to use as RSLinx for the Toshiba? Also, the toshiba plcs are on a fixed scan rate, so anything I do cannot effect that. Please help.
Has anyone had any luck getting a Rockwell PLC (Compactlogix with Ethernet/IP) to communicate to a Toshiba TS3000 with Ethernet/IP. I imported...
1,699
Can anyone help. I have an old toshiba ex M40 which needs to be updated to a Rockwell PLC (probably micrologix). I have (what i believe is) an old...
1,971
Hi, I am looking for manual book plc toshiba ex 40 plus, these part have prob led error lit Please help me to solve this problem, thank you in...
1,849
Hi everyone, I need to interface an external PC with a Toshiba T3 CPU (model PU326H) in order to read data from several 'F' registers. The...
2,846
I've got a Red Lion G304K200 HMI connected to a Toshiba T2N PLC, and I am attempting to display a pressure value, which has the address of XW000...
33
11,291
