Toshiba T1 PLC, Data Link
agcjlw
Oct 2008
Vernal, Utah
subject: Toshiba PLC, (T1 or T2N) they both have a nifty little setup to network two of them together to pass data between them.
it's called DATA LINK you can hook them up in little time and it's a very cheap net work ready to go, I thought that I could make it wireless and thats where it stops, zero communication.
Life would be great if I could use the Toshiba Data Link Mode for wireless radios point to point. When hard wiring RS-485 ports between two T1's the Data Link Mode works great! The PLC are set with 1 as station 1 (master) and 1 as station 2 (slave)
Toshiba does not post any info about: Baud rate,start bit,Data bits, Flow control,Parity,stop bit. for Data Link.
So I called the Toshiba tech guy and he said that other wireless user have had the same problem, I ask about the Baud rate,parity,etc... he said that he didnot know what the settings were either. Then he said use the Free ASCII mode, I said ok... I tried it and got it to work on a very small program (one relay) but the code that one must write is more than I can handle.
So if someone has had secsess using the Toshiba Data Link with
RS-485 wireless radios please let me know. thanks.
Hi everyone, I need to interface an external PC with a Toshiba T3 CPU (model PU326H) in order to read data from several 'F' registers. The...
2,846
Has anyone had any luck getting a Rockwell PLC (Compactlogix with Ethernet/IP) to communicate to a Toshiba TS3000 with Ethernet/IP. I imported...
1,699
Can anyone help. I have an old toshiba ex M40 which needs to be updated to a Rockwell PLC (probably micrologix). I have (what i believe is) an old...
1,971
Hi, I am looking for manual book plc toshiba ex 40 plus, these part have prob led error lit Please help me to solve this problem, thank you in...
1,849
I've got a Red Lion G304K200 HMI connected to a Toshiba T2N PLC, and I am attempting to display a pressure value, which has the address of XW000...
33
11,291
