touch panel mitsu
  • Thread starter billy(unregistered)
  • Start date
billy(unregistered)
Guest
B
Hi! We have a mitsubishi touch panel which is used on FXoN-24MR in our water treatment system. At the back of the panel there is an RS-422 terminal female(9pin) and also an RS-232 terminal male(9pin). The RS-422 terminal is connected to the plc so that you can start, stop, reset in case of emergency, or change the setting of the timers on the touch panel.
PLC(8pin male)---cable------(9pin)RS422,Touch Panel,RS232.
Just want to know is it possible to us that panel to another Fx series model, and transfer a program from the computer to a PLC (ohter fx plc) using those RS422 and RS232 terminal? Will it affect the setting of the panel if I will used its RS422 and RS232 terminals to load a program from medoc to another plc(fx models)? By the way the com terminal of the computer is also male, so will I just use a female adapter to connect from rs232 to com?
regards,
bill
there are more kinds of touch panels so witch one do you have?
i know if it is a F940GOT it can also be used on a FX1N and 2N
We broke the glass on the new PanelView Plus 7 .... 2 months after the install. Our vendor stated that we cannot buy the repair parts...(Touch...
212
Does anyone have any good recommendations on an industrial touch screen panel? I want to be able to panel mount the screen and have it connected...
2,778
We had a sharpening machine. It used Siemens S7-200. The touch panel Simatic 6AV6642-0DC01-1AX0 can't be used but still got display. How to...
3,570
Any suggestions for suppliers in Europe or even Sweden? Or brands and I can look for suppliers. Haven't bought in a while and now my mind's...
4,327
Hello Dears We have a plastic injection machine iml The problem now is that the touch panel has been off for a long time And now that we want to...
2,818
