TP170 B -printer problems
patrikjo
Feb 2004
I have a Siemens touch panel TP170B attached to a printer (Epson LX-300+) via a serial cable. Im using the print screen command in ProTool to print the contents of the screen. This will print in graphics mode, but i would have liked the printout to be in text charachters (since this will take up less space on the paper,use less ink/ribbon and since I am only printing characters it should be possible I think).
Any ideas/suggestions on how to do that?
Thanks in advance
regards Patrik
You cannot print the content of the screen otherwise.
But you can also print alarm messages and event messages (attribute "Print").
You could setup one or several event messages, and format them to include both text and variables. But you are limited to 70 characters all included.
From OP/TP270 and up, you could make reports that could fit a complete A4 page.
Hello everyone! At present, I have 2 PLCs S7200 and 2 HMIs TP170. I want to connect them together. However, I don't know how do I do? May I have...
2,877
Dear Expert, Is it possible to use s7-300 PLC with TP-177 Micro or TP-170 Micro? If yes, How? if No, Why? Do i need some special device or...
4,092
my machine has siemens touch panel.TP170A now there is no backlight in the panel and i couldnt able to read easily. but program is there is...
1,536
Hello we have machine using siemens touchpanel TP170A suddenly from yesterday there is no light but there is display in panel which is...
1,687
Dear all, I was uploaded program from TP177A (Touch panel Simatic TP170 series), i just get PSB file right? So, can i modify it? I want to see...
2,922
