Revision History, viewing
Examining a project file's revision notes (History) can help you to identify changes that you made to the program since the last time the file was saved. This can be a valuable feature when troubleshooting an RSLogix project.
With a project opened, click the Edit menu item and then click Revision Notes. The following options are available on this dialog box.
- Use the Previous and Next buttons to view the revision notes.
- Modify, add or remove (via the backspace key on your keyboard) information from any notes and then click Accept to keep your changes. Do not use the Delete button on the dialog box to remove only portions of text. The Delete button removes the entire log entry.
- Click Delete to remove the entire note from the log. The note deleted is the note indicated at Revision: on the upper portion of the display. Deleted notes cannot be retrieved.
- Click OK to save any changes an exit the window.
The Revision History is saved with the .RSS file.
