Transfering program to TP 170A
johnny smythe
Sep 2005
appleby
Iam having problems transfering program from my laptop to a tp170a HMI
The laptop is running winccflex compact ,over rs232 cable .
But when i try to transfer i get an error message
"Wrong vershion ,change either the hmi vershion or the program vershion.HELP PLEASE
I remember we had this fault some time ago. It has something to do with the version of Windows CE that is on the panel. The project you are trying to download has been created in a later version (or something like that)
From memory you need to run a program called (believe it or not) "wipeout.exe" which is on the Siemens MicroWin CD. This will take the firmware back to default and then you should be able to update the firmware and then download the project.
Good luck,
Dave
Thank dave
You know method for update firmware of TP170A and S7-300 CPU?. I must buy new firmware and use special device?
Huynt, it's been a long time but from memory all you need to upgrade the firmware in the S7-300 is the standard download cable. There's a button in Step7 (somewhere) that starts the process, providing you have the updated firmware file.
I think the TP170 method is what I described above, but I'm not exactly sure.
Have a look at www.ad.siemens.de and drill down in the support pages.
Good luck
TP 170a download problem
Thanks Dave pointed me in the right direction,
Found in wincc flex 2005 compact under the
PROJECT TAB/
TRANSFER/
OS UPDATE/
Click OS UPDATE , wincc flex will update the panels operating system over the rs232 cable.
This fixed it for me.
Johnny Smythe
Dear friends, I have a problem with my Siemens OP 15-C2. I have accidentally erased program from OP. I need to restore it, but I don´t have...
2,034
I hope someone has done this before. I am trying to setup communication on my pc via the Ethernet connection to the HMI so I can transfer the...
2,037
AB 1200P 6181P Needing to transfer .cli file from one 1200P to another. I've loaded the file to the new one but it will not open. File name is KM...
1,294
Hi guys. I am using RS Studio v24 and I have a structure BOOL[2048] inside. When I give project to our HMI designer he sees that array of bools...
2,192
Hi, I've been trying to run my project in Simulation (and check display on VNC viewer). When I try to download a procjet to simulator, then I...
1,525
