Transmission errror, OP17
DUY
Guest
D
Hi!
I control 2 motors via OP17 connected with S7 400, all is ok but when I run the second motor OP17 diplay message :
$044 TRANSMISSION ERROR No 8
and OP17 RESATRT.
I've check all thing I know: cables, power supply, port DP/MPI,address ...But I can not figure out the problem!
Can anybody help me?!!
Any infomation will be appreciated!
Duy
How about joining the forum?
Could it be noise? Sounds like it may be.
I am looking for a method which transmit OPEN/CLOSE signal from "A" Pump Station to "B" Pump Station. (a) There is no wire connection between...
1,238
Hello, I have been playing around with the DDE/OPC topic configuration in RSLinx to make an excel spreadsheet that pulls live data from a...
1,749
I have a tool at the end of a 200m cable. Through this cable I am powering a 50kW/3,000V and a 1kW/480V motor, both with VFDs. So there is going...
42
12,977
I have a one thermocouple that is connected to temperature module 1769-IT6 that accept thermocouples on a compact logix 1769-L33E chassy.I have a...
1,410
Hello, experts! I poll some holding registers on Micrologix 1400 through Modbus TCP. The PC and the PLC are connected directly with Ethernet cable...
2,207
