Transparent mode - RS232 Gx developer to Got
Mar 2009
Leeds
49
I'm trying to manually convert a Beijer E200 HMI project onto to a new Mitsubishi GOT gs2107-wtbd. The PLC is a very old A-series AS1CPU and is connected via is only port RS485.
I've got a e200 programmed up with the original e-designer project and connected to the AS1CPU using its only port RS485. I can then go transparent mode to PLC and monitor/download the PLC code using GX Developer using the RS232 port on the e200 to my PC com port.
RS232 cable I'm using is CAB 5.
Should I be able to do the same using the new GOT and its RS232 port as I ticked the option in GT Designer 3 but can't get it to work. Currently using usb to program the GOT.
I've uploaded a couple of screen shots to my google drive but not sure how to insert image so there's just a link sorry.
https://drive.google.com/file/d/1zHQvnPPXrqJhk9JqxS55gZ1pv4H1n_uH/view?usp=sharing
https://drive.google.com/file/d/1Pm-S-DLxzUQjeN6kBsJi5ACudWZPsJXB/view?usp=sharing
This is my GX Developer transparent mode settings for the e200 which is working but when I select the other two GOT options doesn't make it work for the GOT though.
Hi, I am using CM_CAN in my project in Transparent mode. The CAN modules needs transmit 240 message definitions each of 8 bytes, 168 message...
84
Hey, I have a small problem that I hope someone here could help me with. I'm trying to set up a transparent mode so I can monitor my program...
1,883
I am asking on here in case anyone has come across this before. I have also asked it on mrplc.com to try reach a wider audience as I am a little...
2,235
Hi, I am trying to get transparent mode working with an E1012 and a FX3G plc. We have had no problems using a FX1N but no joy with the FX3G. Cable...
3,820
I cant seem to get the transparent mode to work. I have a Mitsubishi (Beijers) E1101 connected to a Q02 CPU on RS232. I then have my laptop...
3,989
