Trending WinCC Flex <--> Wonderware
userxyz
May 2002
any
2,768
A customer of ours has 2 allmost identical installations. 1 programmed by us with a 319 CPU and an MP377 and 1 programmed by a French company. They used a 317 CPU and Wonderware for HMI.
On the Wonderware, there is a trending of 6 vars. 6 Y-axis. The X-axis is Date & Time. This is long-term archivieng. The Wonderware runs on a PC that can be found in the electrical closet. On the outside it's a touch screen.
Wonderware is more Scada then HMI I guess..., because WinCC can do also long term archieving, can have several Y-axis, ...
Our customer wants the same on the MP377 or a PC Runtime that runs on a server.
1. Can I have more then 1 Y-Axis ? If not, I can try to show several trendings in 1 screen...
2. WinCC and Wonderware can have long-term archieving. What's possible in WinCC Flexible in an MP377 and what's possible in a PC-Runtime ? A sample every 5s of every var (6 vars) is enaough.
Thanks,
Gerry
1. Each trendview can have two Y-axis (left and right).
2. You can log to an archive, and the trend views can be setup to display archived values. It requires an archiving license on both MP377 and PC RT. The MP377 also require a flash card for the archive storage.
ok
I understand. Thanks !!
BTW: Seen our Belgian pride in Oslo ? It's not really far from your place :).
Quest
Are you sure that there is a license needed on the MP377 todo logging ?
I have made 2 screens. Trending Archive and Trending Actual. Trending archive opens data logs (csv files). Trending Actual is a cyclic realtime trend. Works very well, but now the archive data...
How long can we log ?
I have selected 'Create segmental circular' with 500 files and 50000 records in each file. This will be less then a year in total, because I log every second.
Are there other methods, maybe via SQL or whataver... or maybe I need to consider a script that writes the log files away...
Any ideas ?
Thanks in advance.
Hi, I need recommendation for a best solution of trending data on the PC. We have a S7-300 with a PN port and S7-300 with DP/MPI port. We would...
1,264
I am trying to start and stop a trend via a tag from the PLC. I have 8 things happening at once and would like to have all 8 things independently...
1,897
Hi, I'm a student in automation, new to this forum, and hope for some help. I have searched the forum for an answer, but maybe my question is too...
1,860
hello, I'm using wincc 7.0 and it is working fine, except for the trending. The trending is only showing values up to 7 days. The client wants a...
1,711
Hi, I'm doing trending in realtime in one screen and on an other screen logs are called in the trendview. Every second there is a record. All...
2,628
