MJK4826
I have already synced the .MAP file containing all the tag names from the WinPLC to the C-More Micro software. Although I am using an older version of Think 'n Do (used for programming the WinPLC), everything still seems to be supported between the two platforms, with one exception, and thus my problem. In the C-More Micro programming software is a menu option listed under 'SETUP'-->'PLC to PANEL.' This menu contains a few key variable communication options that allow the PLC to change the backlight color, turn the beep on or off, etc. After looking through the addressing and data type help menus for both systems, the HMI software is expecting unsigned INT16 or BCD data types to be used to enable the PLC to make the aforementioned changes. I have now tried setting up the WinPLC to use the following sensible data types: registers, numbers, float, strings, and arrays (though I'm not sure if I set up the array properly.) At any rate, none of these data types were acceptable to the HMI software, and in fact the HMI software claims that registers (which seem to be the best option for what I need to do here) are a completely UNSUPPORTED data type between these two platforms. So might anyone know what else I can try to make this work?
