Tsx 17
porky
Oct 2002
Maia
76
Hello to one and all
I was recently called out to sort out a problem on a water filteration system.. I was met with a TSX17 plc... I have never worked on one before and it seemed quite straight forward, but Then I came accross a symbole which lost me.. :) the following -------(#)
no address or label... There are quite a few of these.. I sorted the problem but would like to know what that means...many Thanks
I don't know the Tele PLCs, but could it simply be a 'continued on following rung' symbol?... :confused:
| (#)----] [----] [----] [----] [------(OUT)
The # might get an actual number next to it if there are more than two targets.
beerchug
-Eric
Olá Porky, bem-vindo
I can check Monday, but I believe that's GRAFCET.
Telemecanique used to have those simbols and others like ==POST== to simulate the GRAFCET. If you can post more code it will help.
João
Everything was working fine, but suddenly CPU went into error mode, and the ERR and TER LEDs lit up. Now I can't download or connect with the PLC...
87
After updating a panel, I inherited another PLC for my "learning lab". It's a Modicon TSX Micro. I've not worked with a Modicon PLC yet, so I...
164
Hello Dear Experts I have to read 2 words (%MW300 / %MW301) in a M221 plc (TM221ME16R/G) which have a embedded ethernet port. the reader plc...
753
My plc is stx micro 3722 My problem is err led is flashing I tried to re programme my plc with pl7 programme The pl7 tel me cant connect with...
377
Hi All Desperatly trying to get hold of the software too upload a program from a TSX Nano. i thinkg the software is PL707. i have from PL7Pro...
425
