TSX Micro 3705
Jul 2002
Hi, everyone. I'm trying to communicate with a PLC TSX MIcro 3705 using FIX Intellution or Lab Windows CVI, but I can't communicate.
I've tried configuring the TER port like a Modbus slave, but I can't talk with the PLC. I don´t know if I'm using the correct Modbus registers or what is the problem, I need help!!!!!!!
Francisco,
Have you verified your cable you are using is properly pinned? You also might want to see if Intellution or Lab View has a Unitelway Driver, since this is the protocol that comes standard on a TSX37 PLC.
Regards,
Eric
More info
I´m using the TSXPCU1031 cable that this PLC uses to interface with computer, but it could be the wrong cable?
Fix Intellution have a Unitelway driver, but it seems only works with TSX17 or TSX47 and where can I find how the registers are managed?
Thanks if someone can help me with this new info,
Fco Calleja
After updating a panel, I inherited another PLC for my "learning lab". It's a Modicon TSX Micro. I've not worked with a Modicon PLC yet, so I...
139
My plc is stx micro 3722 My problem is err led is flashing I tried to re programme my plc with pl7 programme The pl7 tel me cant connect with...
368
I'm working on a Schneider TSX Micro TSX3722001 with an alternately flashing ERR and TER led. The machine has been idle for about 3 years and I...
990
Pure mind boggled at this one, can’t seem to figure it out. NO contact with - %M130(%MW11) How is this possible? Is the %MW11 0 it’s logic 0, 1...
1,538
Hi All, i have PLC Modicon TSX 3722 Micro i need to know where should i put the socket of programming cable on Ter or Aux port. and i see the file...
1,637
