TSX37 micro - Unitelway - WIncc Flex OP277
userxyz
May 2002
any
2,768
I want to connect a TSX micro PLC (modicon) to a OP277 Siemens Panel.
I've done the research, it is written in de manuals that this is possible.
But what about the cable. I have several convertercables, but that's for making a connection between RS232 and Modicon PLC.
But I have to uwe the Profibus RS485 port on de OP277 panel... so these converters are not applicable.
Are there cables for making an RS485 connection tot the TSX37 micro PLC ?
Thanks,
Combo
What kind of port does the TSX PLC have ?
If RS232, then there is this RS422/RS232 converter that you install on the port on the Siemens panel: 6AV66718XE000AX0
The Dip switches on the rear of the Siemens panel must be set to RS422/RS485.
Rs485
Rs485.
what kind of port does the tsx plc have ?
If rs232, then there is this rs422/rs232 converter that you install on the port on the siemens panel: 6av66718xe000ax0
the dip switches on the rear of the siemens panel must be set to rs422/rs485.
hello,please can you explain me how to install TSX37 operating system version 6.5 in pl7 pro
1,559
Hi all, i have to make a few minor changes to a Telemechanique TSX31-21 plc next week. I have never used the software before and know nothing...
2,082
I need to modify a Unitel-way communications driver to talk to Schneider-Telemecanique TSX 57's. Looking for the Unitel-way command frames that...
1,786
I'm looking for a way (gate, card, ....) to connect a TSX37 from SCHNEIDER to a profibus network (ET200S from SIEMENS). Who can help me.
2,291
A
I'm going to make an application with an Telemecanique TSX37 plc. I will replace an exsisting Westinghouse PC1100, and I have a printout of the...
3,013
altivar
A
