TT (timer timing) in CX Programmer
mbruins
Jan 2017
NC
newbie here. I have written and worked with a few AB programs in both RS500 and 5k, in a very limited fashion over the last 10 years. I'm a mechanical engineer for a small company and have to wear a few hats, so I do what I can with PLCS.
I am currently working with an older piece of equipment that has an existing Omron CQM1 controller in it. I am in the middle of programming a couple of additions to this machine and I am trying to learn how to use CX programmer (version 4).
From my AB days I was able to create an XIC contact that was true while its associated timer was timing, using the TT argument. I find myself wanting to do the same thing in CX programmer, but it doesn't look like the CX programmer environment allows such a thing.
An AB version of what I am trying to do is attached. Is there an equivalent way to do it in CX?
Thanks for any help in advance!
You'll have to "roll your own", Omron doesn't use a Control tag for its timers.
For reference, the T memory is Boolean. (On when the timer is elapsed and off when it is not)
Easiest would be to OR branch around your timer block, and have a -|\|- T000 driving a coil.
I re-read my post and felt it may have been a little lacking on detail, so I figured I'd draw something up to try and clarify.
| 0.00 |
|---| |------------------[ TIM 0000 #10 ]---|
| | T0000 |
| ---|/|----( 20.00 )---|
20.00 would be the equivalent of a .tt
Ok guys I have a strange one. I just added a timer to to ML 1400 program, and it is not accumulating anything. But the OTE after the XIC TT...
2,008
Hi there, I am accustomed to working with Logix 500 but have a program modification I need to do on a CompactLogix.... I created a timer...no...
2,458
Why is it that I Can't drag Done bits from timer, when I can drag Bit values into an instruction?
2,401
Hello, I am looking for the best way to monitor that a timer is timing in unity pro. I am used to having the .tt bit. I see that I can see the...
2,831
Hello, How can I monitor that a timer is timing, in unity pro? Like in rockwell the timer will have a .tt bit. This does not seem to be the case...
1,977
